Save dialog box = Spacebar = Don't Save
Dacicusan
Post by Dacicusan » Sat Oct 14, 2017 4:19 am
Will be good to change the default behaviour of the Save file dialog box, so if I press the Spacebar in this dialog box to select automatically the Don't Save button instead of Save. Save can be triggered with Enter. This is the default way a lot of other softwares behave under macOS.
