Scale Radius ...
Scale Radius ...
Post by Husky » Sat Jan 17, 2015 9:47 am
Hi Andrew - nice update! Thank you!
Question:
I found a scale option in the DIM Radius/Diameter section. What can I do with this scale? What ever I tried ..... I failed! :shock:
Clive
Moderator
Re: Scale Radius ...
Post by Clive » Sun Jan 18, 2015 10:21 am
Hi Husky
Looks like you found a bug.
The scale option works okay with the other relevant dimension tools!
