Optional drawing tabs
Sazhen86
Post by Sazhen86 » Mon Jan 23, 2012 8:50 am
Hi
I'd like to suggest hiding the tabs above the drawing window in the case where only a single drawing is open. The tabs take up a fair amount of vertical space.
Rick
Clive
Moderator / Drawing Help
Re: Optional drawing tabs
Post by Clive » Tue Jan 24, 2012 12:35 pm
Sazhen86 wrote:Hi
Rick
Rick
Personally I prefer having the tabs there for reference and I find it helps my work flow.
But you could add your idea as a feature request here;
http://www.ribbonsoft.com/bugtracker/
(you will need to register to use it)
Suggestions for more vertical space
1. If you dont need the rulers, you could hide them - Edit > Application preferences > Graphics view then check/un-check rulers. (you will need to re-start QCAD for this to become effective!).
2.You could un-dock the command line and re-dock on the right-hand side.
Hope this helps.
Sazhen86
Post by Sazhen86 » Tue Jan 24, 2012 8:49 pm
Clive
Thanks for the tips. I'd found the option to hide the rulers, but I didn't know about moving the command line.
I'm happy to have the tabs when multiple drawings are open, but it seems to me to be a waste of screen real estate when only a single drawing is open.
Cheers
Rick
Jef
Post by Jef » Fri Dec 25, 2015 2:45 pm
I'm bumping this request because I too find the tabbed interface quite wasteful to me since I only ever work on 1 drawing at a time. And for the very rare case I do have more than 1 drawing open, the "Window" menu is there to switch drawings.
I think the best solution would be for QCAD to do it like Scribus: make this an interface setting. But maybe this would be easier with Qt5?
