User-defined Global scale for Import Bitmap?
DerekGove
Post by DerekGove » Wed Jul 26, 2023 1:17 pm
Hi all,
I'm currently using QCAD to produce specification sheets for work, and this includes orthographic and an isometric images rendered from a 3D package.
I render them at 10 pixels per mm, and they need to be printed at actual size.
When an image is imported with 'Import Bitmap', it defaults to 1 pixel to 1mm. This is a sensible and understandable setting. But for each of my images, I have to click in the Width or Height field in the toolbar, and insert a decimal point before the last digit to rescale it.
Whilst this isn't a massive workflow issue, it would really streamline things if I could tell QCAd in the preferences that (for example) all my imported bitmaps should be scaled to 10 pixels per mm.
Cheers,
Derek
QCAD Version 3.29.4 : Windows 10
Re: User-defined Global scale for Import Bitmap?
Post by CVH » Wed Jul 26, 2023 5:47 pm
Derek,
This is not implemented, by default it is 1 pixel per drawing unit.
Maybe you can play with the actual drawing unit and the convert between units.
Post by CVH » Wed Jul 26, 2023 6:51 pm
Still, the single addition of a decimal point is by far the easiest method.
The tool could include a Scale factor and save that persistent like most other tool options.
For such a request it would be better to open a feature request at Bugtracker:
https://qcad.org/bugtracker/
You need a separate account there or make a new one.
