Basic Pattern Maker [ Windows & Linux ]
layna54
Re: Basic Pattern Maker [ Windows & Linux ]
Post by layna54 » Sun Feb 18, 2024 1:59 pm
John Hyslop wrote:
Sun Jan 28, 2024 3:52 am
Hi All
Was just playing around today with this very basic pattern , it's a good example of the use of lines and points in BPM..
Here's a copy of the sketch file [ *.bpmlc ] FM Whatsapp Download
bpm-cross-02.bpmlc.zip
Happy Hatching :D
Cheers
John & Pete
Thank you for sharing this nice post.
John Hyslop
Post by John Hyslop » Sun Feb 18, 2024 11:51 pm
. Thank you for sharing this nice post.
You're very welcome Layna54
Happy Hatching :D
John Hyslop
Post by John Hyslop » Sat Mar 23, 2024 7:03 am
Hey All
Here's one I did today... this is how I sometimes go about making patterns, you find the repeat that would make it seamless then draw it in Qcad on the grid that best fits..
As you can see I used the blue markers on this pattern to help me line it up vertically.. :wink:
The perspective tool didn't work too well on the door image so the rectangles are a bit out of whack :lol: but it gave me some info to start creating this pattern.. BPM sketch files attached..
bpm-screens-06-07.zip
(1.24 KiB) Downloaded 19 times
Creating Patterns With BPM.png (156.77 KiB) Viewed 357 times
Happy Hatching
John & PeteVick
John Hyslop
Post by John Hyslop » Sun Apr 14, 2024 9:25 am
Hi All
Here’s another example of how you could use the blue markers to help you draw a pattern.
In this example I’m using “bpm-herringbone3-1.bpmlc” which you can find in the downloaded zip file folder called BPM-Sketches.
This pattern has been drawn on a 6x6 grid, to enable us to place gaps between the boards we’ll use a 36x36 grid “which is dividable by 6”, mark positions with the “Blue Markers” and redraw the original which will give us a our guides, these are later removed by using the "Edit Mode" feature in the App.. The gif below shows the steps.
This link explains how to create ratio herringbone patterns with BPM.
https://qcad.org/rsforum/viewtopic.php? ... 995#p42150
Happy Hatching :)
John & PeteVick
