New library developer - Debugging
sandyg
Post by sandyg » Thu Dec 12, 2019 10:58 pm
I just started playing with creating a library plug in, based on the Gears one that I found.
What is a good way to log to the QCAD console in or other simple ways to output debugging information. I have hacked things up enough from the sample InvoluteSpur.js (Gears) file but have some simple bugs that I can't see to find.
I tried qDebug("xxx") as well as console.log() but I'm not sure those are right for a library script.
Any other tips for a newcomer with debugging help very much appreciated.
Sandy
Re: New library developer - Debugging
Post by CVH » Fri Dec 13, 2019 8:08 am
Win or ....
Win = problematic.
I have a post on that, but can't find it.
look at:
https://qcad.org/rsforum/viewtopic.php?t=5687
https://qcad.org/rsforum/viewtopic.php?t=6215
Or search further with keywords from there.
Post by andrew » Fri Dec 13, 2019 8:28 am
qDebug("message") writes to the system console from where QCAD was started (i.e. the terminal, stderr).
To output to the QCAD command line history widget, you can use EAction.handleUserMessage("message");
sandyg
Post by sandyg » Sat Dec 14, 2019 2:40 am
Thanks all for the suggestions!
I am running on windows, so I'll take a look at the threads and see if that will help out.
I'm sure I'll be back for more questions and help ;)
Sandy
