Free Hatch Patterns
- Premier Member
Re: Free Hatch Patterns
BARBWIRE Hatch Pattern, Handy for Architechs Adding Wire to Fences
- BARBWIRE - Metric and Imperial.zip
- (2.5 KiB) Downloaded 630 times
- barbwire.jpg (61.31 KiB) Viewed 20667 times
- Premier Member
WIRE-FENCE Hatch Pattern
- WIRE-FENCE - Metric and Imperial.zip
- (1.13 KiB) Downloaded 647 times
- WIRE-FENCE.jpg (58 KiB) Viewed 20662 times
- Premier Member
An example of the previous Hatch Patterns in use...fill borders on Layer Invisible ...
- Basket.jpg (58.57 KiB) Viewed 20660 times
- FENCE.jpg (501.69 KiB) Viewed 20661 times
- Premier Member
LOOPLINKS Hatch Pattern..This Pattern Has been Removed and Will be updated ASAP
New Updated Pattern now on Page 4 of this topic
- LOOPLINKS.jpg (109.06 KiB) Viewed 20658 times
- Premier Member
Hi Andrew
I noticed in Qcad 3.24 that small lines are rendered as points, this is good but I had to redo LATTICE-02.PAT
manually as it had a Zero on the end of 2 lines, I've commented in PAT files where... if the current Pattern
File is Exploded it shows these points and sometimes even if not exploded also shows them slightly.... anyway
here are the updated Files please just write over the older ones..see what I mean by points in image below..
- Fixed Lattice-02 Pattern.jpg (16.69 KiB) Viewed 20625 times
- Lattice-02 - Points.jpg (19.59 KiB) Viewed 20626 times
- LATTICE-02 - Imperial and Metric Updated.zip
- (595 Bytes) Downloaded 611 times
- Premier Member
Hi All
I'm Currently Testing out this tool "Tile2Hatch tool © CVH 2020" It seems to work flawlessly even at testing stage so
I'm posting all my patterns now using this tool as the AutoCad one has a lot of limitations... all header files will
contain this message to credit CVH on his amazing work on this tool that runs in Qcad
*HATCHNAME
;By John Hyslop, Tile2Hatch tool © CVH 2020
;Developed in inch as imperial QCAD3 pattern
AND
*HATCHNAME
;Developed in mm as metric QCAD3 pattern
*HATCHNAME
AND
*HATCHNAME
- Premier Member
Files Attached In Imperial and Metric
BUBBLES-01,BUBBLES-02, LEAF-01 and LEAF-02..
Using Tool Developed by CVH "Tile2Hatch tool © CVH 2020"
New Updated Patterns now on Page 4 of this topic
- Bubbles-01 and 02.jpg (84.55 KiB) Viewed 20540 times
- Leaf -01 and -02 Patterns.jpg (120.3 KiB) Viewed 20546 times
- Premier Member
HATCH-DOTS and HATCH-SQRS in Metric and Imperial
- HATCH-DOTS - HATCH-SQRS - Metric and Imperial.zip
- (1.65 KiB) Downloaded 610 times
- HATCH-DOTS-SQRS.jpg (130.81 KiB) Viewed 20520 times
- Premier Member
Optimised Patterns Please replace older patterns with these ones
Patterns Will be updated ASAP
SCAFFOLD PATTERN HAS BEEN UPDATED, PLEASE SEE POST DATED 11/01/20
SQUIGGLE-01 & SQUIGGLE-02 Have been updated and can be found on page 4 of this topic
- Optimised Patterns.jpg (206.8 KiB) Viewed 20490 times
- Premier Member
LEAF-03 PATTERN
Pattern Will be updated ASAP
- LEAF-03.jpg (132.66 KiB) Viewed 20436 times
- Premier Member
LATTICE-07 Pattern [ Similar to LATTICE-02, but woven instead of overlapped ]
You Can Also Create This With My Free Basic Hatch Tool, That Can Be Downloaded Using The Link Below..
https://www.qcad.org/rsforum/viewtopic. ... =15#p33566
- LATTICE-07.jpg (85.78 KiB) Viewed 20402 times
- LATTICE-07 - Metric and Imperial.zip
- (666 Bytes) Downloaded 604 times
- Premier Member
WEAVING Pattern
WARNING This uses a lot of resources use wisely
- WEAVING.jpg (202.24 KiB) Viewed 20400 times
- Premier Member
UPDATE TO SCAFFOLD PATTERN
DUPLICATE LINE REMOVED - 11-01-20
- SCAFFOLD - Metric and Imperial.zip
- (1.38 KiB) Downloaded 598 times
- Premier Member
Hi All
As you are all aware CVH discovered that some hatch patterns when hatched far away from the drawings X Y Origin start to lose accuracy , this is due to the limitation of the number of decimal points used to calculate entity positions at that distance. Although it's not the norm to hatch at such distances, we have come up with a workaround if needed, simply click on the pattern that has lost it's definition and reset the hatch origin... see screenshot below. I will be reinstating the patterns I removed recently as we now know what is causing this...
The Installed AR-CONC.PAT does exactly the same thing and that's been around for years
- Drifting Hatch Patterns.jpg (158.11 KiB) Viewed 20135 times
- Premier Member
New Updated Patterns now on Page 4 of this topic, The QCAD-LOGO was kindly fixed up by CVH , he edited 1 line of the code that was making 1 side of the pencil shift...dramatically [/size][/b]
