Free Hatch Patterns
- Premier Member
Re: Free Hatch Patterns
Hi All
I've added headers to all my hatch patterns the header contains this text as suggested by CVH
;By John Hyslop
;Developed in inch as imperial QCAD3 pattern
Here is a fullset of all I have done so far if using Metric download the metric set.. Enjoy
The Dotted Circle Hatches are made with short lines.. not the best practice but ok for representations..
Some Pattern Updates are now on Page 4 of this topic
;By John Hyslop
- Set of 15-Hatch-Patterns.zip
- (13.25 KiB) Downloaded 613 times
- 15 Qcad Imperial Hatch Patterns.jpg (197.43 KiB) Viewed 19476 times
- Premier Member
Seamless MAZE-02 Coming soon
Forgot the LATTICE-04 Ortho....
You can use 0 (zero) for dashes 1-6 instead of a positive number.
That would render to a dot.
Positive is the length ON.
Negative is the length OFF.
dashes 5,-3,0,-1,0,-1 would be:
bar(5long), space(3), dot, space(1), dot, space(1)
- Premier Member
Qcad Metric Hatch Patterns
Some Updated Patterns are now on Page 4 of this topic
- Set of 15-Hatch-Patterns [ METRIC ].zip
- (15.19 KiB) Downloaded 590 times
- Qcad Metric Hatch Patterns.jpg (205.94 KiB) Viewed 19419 times
- Premier Member
MAZE-02 Seamless in Imperial... Metric File to Follow
- MAZE-02.pat
- (1.24 KiB) Downloaded 583 times
- MAZE-02.jpg (66.24 KiB) Viewed 19416 times
- Premier Member
MAZE-02 Seamless in Metric
- MAZE-02.pat
- (1.54 KiB) Downloaded 591 times
- Premier Member
Hatch Patterns BOXJOIN-01,BOXJOIN-02,HEXJOIN-01,HEXJOIN-02
Metric & Imperial Downloads
- BOXJOIN-HEXJOIN-01-02-Metric.zip
- (1.33 KiB) Downloaded 594 times
- BOXJOIN-HEXJOIN-01-02-Imperial.zip
- (1.23 KiB) Downloaded 583 times
- HEXJOIN - BOXJOIN - 01 - 02.jpg (96.59 KiB) Viewed 19371 times
- Premier Member
LATTICE-05 & LATTICE-06
In Metric & Imperial
- LATTICE-05-06-Metric.zip
- (699 Bytes) Downloaded 588 times
- LATTICE-05-06-Imperial.zip
- (625 Bytes) Downloaded 581 times
- LATTICE-05 and LATTICE-06.jpg (67.12 KiB) Viewed 19370 times
- Premier Member
Australian REDBACK Spider
- REDBACK - Metric and Imperial.zip
- (4.52 KiB) Downloaded 580 times
- RedBack - Spider.jpg (63.08 KiB) Viewed 19363 times
- Premier Member
TRIANGLE & BOX OVERLAP PATTERNS in Metric & Imperial
- TRI-BOX-OVERLAP - Metric.zip
- (784 Bytes) Downloaded 587 times
- TRI-BOX-OVERLAP - Inch.zip
- (712 Bytes) Downloaded 584 times
- TRI-BOX-OVERLAP.jpg (64.86 KiB) Viewed 19172 times
And the not turncated angle would be:John Hyslop wrote: ↑Wed Nov 20, 2019 10:51 pmLATTICE-04 [ see angle note on screenshot ] to make it orthogonal..
If you require a more accurate angle the true one is 26.565051deg :-)
ATAN2(2,1)
Do you see it John? :D
Tiles2Patterns...Closing in on it.
Cheers
- Premier Member
Hi CVH
I private messaged you to keep this area clear for hatch patterns..
Cheers john
Cheers john
- Premier Member
SCAFFOLD PATTERN HAS BEEN UPDATED, PLEASE SEE POST DATED 11/01/20
This Pattern might be handy for builders and architects.
Note: if your drawing is scaled 1:1 Consider setting a high scale
eg. 200 then adjust it to get the approximate size..
Scaled at 200 will result in the platform sizes below:-
Metric = 2540mm Long
Inch = 100" Long
This Pattern is not intended to be an accurate way of drawing
scaffolding , it is for quick representational purposes only
Metric & Imperial Files Included....
Cheers
John
Inch = 100" Long
Cheers
John
- SCAFFOLD-PATTERNS - mm and inch.zip
- (1.45 KiB) Downloaded 521 times
- SCAFFOLD-PATTERN.jpg (138.82 KiB) Viewed 19143 times
- Premier Member
Here's another 2 Hatch Patterns BLOCKS-01 & BLOCKS-02 in Metric & Inch
These could be exploded and used as garden screens cut from corten
steel " steel that naturally rusts " some of my other patterns can
be used for this purpose also eg some of the Lattice patterns..
- PATTERNS - BLOCKS-01 and -02 - mm and Inch.zip
- (2.38 KiB) Downloaded 460 times
- BLOCKS -01 and -02.jpg (97.61 KiB) Viewed 19096 times
- Premier Member
XMASTREE PATTERNS Metric & Imperial
- PATTERNS - XMASTREE-01 and -02 - mm and inch.zip
- (3.54 KiB) Downloaded 419 times
- XMASTREE-01 and -02.jpg (173.24 KiB) Viewed 19094 times
