Doing layer changes in one operation
sarlaa
Post by sarlaa » Wed Jun 27, 2018 11:09 am
How can I remove a layer, and set an other one as current layer in the same operation.
Re: Doing layer changes in one operation
Post by andrew » Wed Jun 27, 2018 1:11 pm
Delete layer "layer 1" and make layer "layer 3" the current layer:
var document=getDocument();
var documentInterface=getDocumentInterface();
var op = new RAddObjectsOperation();
op.deleteObject(document.queryLayer("layer 1"));
var docVars = document.queryDocumentVariables();
docVars.setCurrentLayerId(document.getLayerId("layer 3"));
op.addObject(docVars);
documentInterface.applyOperation(op);
sarlaa
Post by sarlaa » Thu Jun 28, 2018 10:34 am
