catch event key pressed
sarlaa
Post by sarlaa » Wed May 23, 2018 12:24 pm
I have a calculator widget, and I need to get notfied when a key from the widget is pressed.
I saw in LibraryBrowser script :
var dirTree = formWidget.findChild("DirectoryTree");
dirTree.installEventFilter(new REventFilter(QEvent.KeyPress.valueOf(), true));
But I don't know how you link a function for getting notified ?
Thanks.
Re: catch event key pressed
Post by andrew » Wed May 23, 2018 3:53 pm
The code you have posted filters (ignores) key press event for a widget.
To receive key events, you'd have to derive a class from QWidget (or QDialog, etc) and re-implement keyPressEvent or keyReleaseEvent.
I've added an example at:
https://github.com/qcad/qcad/tree/maste ... s/ExWidget
The example creates and shows a widget MyWidget, derived from QWidget and receives key press events.
sarlaa
Post by sarlaa » Fri May 25, 2018 5:15 pm
Thanks for your example.
I don't know why keyPressEvent fires just when I click Enter key.
But when I replace by keyReleaseEvent it works for all keys. Still that fine with me.
Thanks.
