Close document listener
sarlaa
Post by sarlaa » Wed Apr 18, 2018 12:50 pm
Please is there an adapter for listening close document ?
Thanks in adavance
Re: Close document listener
Post by andrew » Wed Apr 18, 2018 1:42 pm
If you want to get notified when user requested to close a document window (but can still cancel the close dialog), you can use the closeRequested signal of RMdiChild:
var mdiChild = EAction.getMdiChild();
mdiChild.closeRequested.connect(myFunction);
function myFunction(mdiChild) {
    var di = mdiChild.getDocumentInterface();
If you want to get notified when a document is definitely about to close and be destroyed, use signal closeAccepted instead.
sarlaa
Post by sarlaa » Fri Apr 20, 2018 12:31 pm
