contextuel dock widget
dalida
Post by dalida » Tue Jan 16, 2018 4:27 pm
New to qcad, I'm wondering if I can add a dock widget and keep it contextuel to document (as Property editor).
In this way if I switch between 2 documents oppened, content dock widget will be related to actif document.
Many thanks
Dalida
Re: contextuel dock widget
Post by andrew » Wed Feb 21, 2018 3:10 pm
You can use a focus listener to get notified when the current document changes. In ECMAScript:
var fl = new RFocusListenerAdapter();
appWin.addFocusListener(fl);
fl.focusUpdated.connect(MyClass, "doSomething");
MyClass.doSomething = function(document) {
    // called when current document has changed
dalida
Post by dalida » Wed Mar 14, 2018 2:37 pm
Thanks !
dalida
Thanks !
