Fusion of shapes
caramel
Fusion of shapes
Post by caramel » Mon Jan 08, 2018 7:05 pm
Please, could you tell me if there is a way to construct a shape base on fusion of other shapes like the piture attached :
newShape = fusion([Shape1, Shape2, Shape3]);
Many thanks!
Caramel
J-J
Moderator
Re: Fusion of shapes
Post by J-J » Mon Jan 08, 2018 9:39 pm
Hi Caramel,
Welcome to the forum.
That should be easy using the "break out segment" (D2) tool, just click on the segments you wish to remove.
JJ Win7 pro-64
Post by andrew » Tue Jan 09, 2018 10:40 am
Presumably, you are looking for a programmatic way (since you posted to the developer forum).
For polygon shapes (i.e. only straight segments), you can use clipper which comes with QCAD Professional:
var clipper = new RPolygonClipper();
// add subject paths (islands: ccw, holes: cw):
clipper.addSubjectPath([new RVector(0,0), new RVector(100,0), new RVector(100,100), new RVector(0,100)]);
clipper.addSubjectPath([new RVector(50,50), new RVector(150,50), new RVector(150,150), new RVector(50,150)]);
// union:
clipper.execute(RS.Union, RS.NonZero);
// print result:
for (var c=0; c<clipper.getSolutionPathCount(); c++) {
    var vertices = clipper.getSolutionPath(c);
    qDebug("polygon:", vertices);
caramel
Post by caramel » Tue Jan 09, 2018 1:34 pm
Hi andrew,
Thanks for your response,
Yes I'm looking for a programmatic way and just for polygon shapes (with straight segments).
I tested your code with QCAD Professional and it works,
But when I test with other shapes :
  clipper.addSubjectPath([new RVector(0,0), new RVector(10,0), new RVector(10,10), new RVector(0,10)]);
  clipper.addSubjectPath([new RVector(-2,2), new RVector(12,2), new RVector(12,-2), new RVector(-2,-2)]);
  // union:
  // print result:
      qDebug("polygon:" , vertices)
      qDebug("area:" , Mod_Line2P.getArea(vertices))
I get these results :
polygon: RVector(12, 2, 0, true),RVector(10, 2, 0, true),RVector(10, 10, 0, true),RVector(0, 10, 0, true),RVector(0, 2, 0, true),
RVector(10, 2, 0, true),RVector(10, 0, 0, true),RVector(0, 0, 0, true),RVector(0, 2, 0, true),
RVector(-2, 2, 0, true),RVector(-2, -2, 0, true),RVector(12, -2, 0, true)
area: 116
When I excpect these results :
polygon expected: RVector(12, 2, 0, true),RVector(10, 2, 0, true),RVector(10, 10, 0, true),RVector(0, 10, 0, true),RVector(0, 2, 0, true),
area expected: 136
Is this a bug ?
Post by andrew » Tue Jan 09, 2018 2:18 pm
I think you might have missed the bit in the code about islands being CCW (counter-clockwise) and holes being CW (clockwise). Your second polygon is CW, hence treated as hole.
You might want to use RPolyline::getOrientation() to check for orientation CW or CCW, RPolyline::reverse() to reverse and RPolyline::getArea() to compute the area.
caramel
Post by caramel » Tue Jan 09, 2018 2:58 pm
You have absolutely right, I missed with orientation as you mentioned, now I get the exact expect results.
Thanks a lot !
