How can i set the width of line?
Posted: Wed Nov 09, 2016 1:09 pm
by liguosheng
I want to draw of line, its' width is 0.15mm, how can I?
thanks a lot!
Re: How can i set the width of line?
Posted: Wed Nov 09, 2016 1:22 pm
Please allow me to refer you to this detailed post about entity attributes:
http://www.qcad.org/rsforum/viewtopic.php?f=47&t=3202
Posted: Wed Nov 09, 2016 1:31 pm
by liguosheng
By property editor, the width of line can be edited. However, if i want to set the width of line before it be drawn, which function can be uesed?
thanks!
Posted: Wed Nov 09, 2016 1:33 pm
In the above mentioned post, please scroll down to "Fixed Attributes".
Posted: Thu Nov 10, 2016 1:57 pm
by liguosheng
by "Fixed Attributes", the width of line can be edited. However, i want to change a line which its' property isn't 'by layer', its' width must be setted by code. When 'setLineweight' is be usede, its' width cann't be changed, its' color can be changed. Why?
Posted: Thu Nov 10, 2016 2:52 pm
by liguosheng
In the commuity version, is the width of line to be setted by code? that is to say, the width of line cann't be setted by code. Only its' color can be setted by code.
Posted: Fri Nov 11, 2016 2:29 am
by liguosheng
when a line is finished, i want to draw some different lines according to the path of the line by code automatically, How is it realized?
Thanks!
can someone help me?
Posted: Fri Nov 11, 2016 8:57 am
setLineweight will set the line weight of an entity to any of the available line weights (see
http://www.qcad.org/doc/qcad/latest/dev ... bea7d2ac58). RLineweight::WeightByLayer is the default value.
Please start a new topic for new, unrelated questions. Also, please be as specific as possible, provide examples, screenshots, etc. to explain what you are trying to achieve. This will greatly increase the chances of getting a helpful response. Thanks.
