Slovak translation
Slovak translation
I have problem with translation, I didn't find some things and something was not translated - have a look at pictures. Could anybody help me?
http://prntscr.com/78jezl
http://prntscr.com/78jhae
http://prntscr.com/78jg2o
http://prntscr.com/78jk20
http://prntscr.com/78jkxn
http://prntscr.com/78jl7r
Re: Slovak translation
Thanks for your report.
The Slovenian translation is a community contributed and incomplete translation (see QCAD features at http://www.qcad.org/en/qcad-documentation/qcad-features).
If you wish to contribute a translation for future released, you can do this online at:
http://translate.qcad.org/sl/
I am making a Slovak translation , not Slovenian ...
- qcad-win.zip
- QCAD version 3.8
- (327.2 KiB) Downloaded 3252 times
I see, sorry about the mixup. I thought you were talking about an existing translation included with a QCAD release.J&J wrote:I am making a Slovak translation , not Slovenian ...
The ZIP file you've attached contains translations for the free community edition of QCAD.
Some menus, tools and widgets are only available in QCAD Professional or replaced by QCAD Professional versions (e.g. the layer list).
You can test if your translation for the QCAD Community Edition is complete by installing the QCAD Community Edition:
http://www.qcad.org/en/qcad-downloads-trial
Be sure to remove the trial plugins from the downloaded package.
If you wish to also translate the QCAD Professional add-on, you can download the translation sources (.ts) from here: It's also possible to do the translation online at:
http://translate.qcad.org/sk/qcadpro/
If you can send me the .ts files you already have, I would also update the qcad translation for sk on our translation server:
http://translate.qcad.org/sk/qcad/
Thanks for your contribution!
Excellent! Thanks a lot for this valuable contribution
I've briefly tried the translation and everything looks fine as far as I can tell.
Please let me know how I can credit you in the about dialog: as "J&J" or with a full name or other pseudonym? Thanks!
You can use full name
OK, great - can you please send me a private message with your full name? Thanks!J&J wrote:You can use full name
ahoj,
všimol som si že v online prekladaní (http://translate.qcad.org/sk/qcad/scripts/Misc/) tieto http://prntscr.com/864dep nie sú
mám ich preložené ... pack.zip
hi,
I noticed that in online translation (http://translate.qcad.org/sk/qcad/scripts/Misc/) these items are missing: http://prntscr.com/864dep
I have translated them. here they are: pack.zip
hi,
- pack.zip
- (12.37 KiB) Downloaded 3262 times
Thanks! Can you also send me the .ts files, then I can add it to git and translate.qcad.org and keep it up to date, thanks.
nech sa páči
here you are
here you are
- pack _ts.zip
- (14.01 KiB) Downloaded 3209 times
ešte som zabudol
one more thing
one more thing
- DevDebug_sk.ts
- (267 Bytes) Downloaded 3228 times
- XLineVertical_sk.ts
- (468 Bytes) Downloaded 3182 times
- XLineHorizontal_sk.ts
- (480 Bytes) Downloaded 3248 times
Thanks! I've updated git and the pootle translation server at http://translate.qcad.org/
translate ... library - gear
Involute Spur Gear <=> Čelné ozubené koleso
Pitch Circle Diameter <=> Priemer hlavovej kružnice
Draw Pitch Circle <=> Nakresliť rozostupovú kružnicu
Pressure Angle <=> Uhol záberu
Number of teeth the gear has <=> Počet zubov ozubené kolesa
Number of Spokes <=> Počet rebier
If non-zero, spokes will be drawn <=> Ak je hodnota vačšia ako 0 bude rebro nakreslené
Axle Diameter <=> Priemer stredovej kružnice
Number of Teeth <=> Počet zubov
Module <=> Modul
- gear ang.jpg (76.45 KiB) Viewed 408140 times
- gear SK.jpg (78.31 KiB) Viewed 408140 times
