Hi, first up, thankyou for an excellent DXF parsing library. I am currently investigating it's use to load and save DXF files with POLYLINE being the main entity I am concerned with.
Most of the POLYLINE entities i've encountered so far store X, Y and Z components with each VERTEX (or in a list for the LWPOLYLINES). The issue arose when I wrote code to save the DXF. I just output the same structs that were supplied to the DXFLib DL_CreationInterface when it loaded the file. When I tried to reload the saved file, it had lost all of the elevation (ie component 30 of the VERTEXs).
After digging around in the source, I found that DL_Dxf::writeVertex() doesn't actually output the 30 component (not in either of the supported DXF format versions). It was easy enough to fix, but I just wanted to ask if there was a reason for not outputting the 30 component when you do actually read the component?
My reason for asking is that I'd prefer not to modify the DXFLib source, particularly if I end up using it commercially (and hence buying a license).
Saving POLYLINE vertices
Thanks for the reply.
Here is the modified function from dl_dxf.cpp:
Cheers,
Aranda
* Writes a single vertex of a polyline to the file.
* @param dw DXF writer
* @param data Entity data from the file
* @param attrib Attributes
void DL_Dxf::writeVertex(DL_WriterA& dw,
const DL_VertexData& data) {
if (version==VER_2000) {
dw.dxfReal(10, data.x);
dw.dxfReal(20, data.y);
dw.dxfReal(30, data.z); // ADDED THIS LINE
if (fabs(data.bulge)>1.0e-10) {
dw.dxfReal(42, data.bulge);
} else {
dw.entity("VERTEX");
//dw.entityAttributes(attrib);
dw.dxfString(8, polylineLayer);
dw.coord(VERTEX_COORD_CODE, data.x, data.y, data.z); // ADDED LAST PARAMETER TO THIS LINE
Aranda
