Features for QCAD CAM Version
RainerP
Post by RainerP » Thu Feb 23, 2023 11:43 am
i am using QCad since more that two years.
For creating the files for the CNC-Machine i use Filou NC.
Now i have taked a look on QCAD/CAM an i have some questions.
1.
Is it possible to create a own PostProzessor?
For my CNC-Machine with WinPCNC as controll system i would create similar CNC-Files until now.
For example the beginn of the CNC-File:
(Programmanfang)
%1 (MAGNETHALTER 5 X 5)
(NC-Datei:C:\....\Magnethalter 5x5 2er Fraeser.cnc)
(NC-Datei-Datum:14.02.2023 15:20:50)
N0005 G71
(Werkzeug Diamantfräser 2mm)
N0010 G0 Z10
N0015 M8
N0020 T M6
N0025 S12 F400 M3
Also i was able to add comments and special programm ends.
(Programmende)
N0365 M5 M9
N0370 G0 Z10
N0375 M30
Also a free numbering of the set numbering and the interval should be nice!
2.
A importand functionality is to expand corners.
Is there a functionality to expand the corners in the CAM module or with a script in QCAD?
As example i have a rectangele and i have to remove the cutter radius at the corners.
Ecken erweitern.png (6.95 KiB) Viewed 9601 times
e.g. If i am using an 2mm cutter, i expand the edges with 2.1mm
3.
Often i need the functionality "Corcle Pocket Milling" and "Contour Pocket Milling".
Is this functionality is planned in the future?
4. In filou i define the function contour milling, then i can select maunal one contour after the other to generate the milling path.
So i am able to make first the holes and then the outer contour. Debending on the site of the contour i click he generate the tool path.
Inner or outer contour.
Inner contour:
Outer Contour:
Sorry that i have so many questions.
Thank you and BR
Rainer
Re: Features for QCAD CAM Version
Post by andrew » Thu Feb 23, 2023 12:17 pm
Yes. Here's a starting point:
https://qcad.org/en/qcad-cam-postprocessor
There's a complete example "MyGCode" and at the bottom an example of how you can change the header / footer.
You can set this.lineNumber and this.lineNumberIncrement to adjust numbering.
No. A feature request exists at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2307
Not in the near future due to lack of resources / other projects.
With QCAD/CAM, toolpaths can be created in the right order or reordered anytime in the toolpath list.
RainerP
Post by RainerP » Thu Feb 23, 2023 12:48 pm
Hello Andrew,
Thank you for the quick respond!
BR Rainer
Post by CVH » Thu Feb 23, 2023 7:43 pm
If you draw an overcut then it will be milled as such.
But I have problems with understanding:
For a cutter with a diameter of 2mm in a 90 degree corner one requires an arc that is offset by 0.292893 in both X & Y.
Or offset by 0.414214 in the 45 degree direction.
Minus 5% would be hammer tight for wooden pieces, plus 10% would add some extra clearance in the corner.
