Trial version
simonwrover
Trial version
Post by simonwrover » Mon Jul 25, 2022 7:21 pm
Good afternoon, I have the trial version and am very happy with it. I want to progress to the full version. Can you please advise if the trial is limited in terms of files it can open? I have several dgn files which will not open with the trial version. Many thanks
Re: Trial version
Post by Husky » Mon Jul 25, 2022 8:18 pm
after doing a few dgn file test with the current QCAD version (Pro and Trial) I've the feeling there is something not working as expected. Please indicate your operation system, the used Trial QCAD version and if possible post a sample dgn file which can't be currently be loaded in your Trial QCAD version. Thanks.
Re: Trial version
Post by andrew » Tue Jul 26, 2022 7:22 am
Note that only DGN v8 files are supported by QCAD. Please attach the file(s) in question.
simonwrover
Re: Trial version
Post by simonwrover » Wed Jul 27, 2022 11:01 am
Window 10 - QCAD trial version
Please see attached the drawing which I cannot open.
Kind regards
Simon
Re: Trial version
Post by Husky » Wed Aug 17, 2022 8:18 pm
@Simon
Thanks for your report. The issue is addressed / fixed and most likely available within the next update.
https://www.qcad.org/bugtracker/index.p ... sk_id=2382
