dwg2maptiles georeferenced?
andrzejdupa
Post by andrzejdupa » Sun Nov 03, 2019 4:49 pm
i would like to buy qcad professional but i don't find answer for my question.
If i use dwg2maptiles to render my dwg file (witch is georeferenced) then the tiles will be georeferenced as well?
in trial version of qcad the output tiles are missing georeferenced and at the leaflet script with base map - openstreetmap the tiles apear in random place on map.
in full paid version will be the same behavior?
Re: dwg2maptiles georeferenced?
Post by andrew » Mon Nov 04, 2019 8:54 am
Georeferencing is currently not supported by dwg2maptiles.
