Snap Lock SQ not working
kharaktur
Post by kharaktur » Fri Jun 28, 2019 6:57 pm
Greetings,
I can't seem to get Snap Lock to work, maybe I'm doing something wrong?
I select a snap say for instance end. Good all endpoints are snapped. Then I enable Snap Lock (command line SQ or by clicking the button) and choose say Middle. Now only mid points are will snap! What happened to endpoints? Seems like the snap lock isn't working. I would expect once snap lock is engaged all selected snaps would appear selected in the toolbox until they are toggled off or snap lock is disabled.
Where do you suppose I have gone wrong?
Version: 3.22.1.0 (3.22.1)
Internet: QCAD.org
Build Date: May 21 2019
Revision: 46d6499
Qt Version: 5.5.1
Architecture: x86_64
Compiler: MSVC++ 12.0 (2013)
Re: Snap Lock SQ not working
Post by Husky » Fri Jun 28, 2019 8:02 pm
below Application Preferences you can set multiple snaps. QCAD will snap to all selected snaps.
If you now select a single snap it will override the mentioned snap collection. But only one time (next snap).
The snap lock will lock this single snap until you unlock it again what means you can use it as long as you need it.
kharaktur
Post by kharaktur » Fri Jun 28, 2019 8:48 pm
Ahhh.. so if I understand you correctly Snap Lock holds the last selected snap through tool changes. Ok, thanks.
