Custum toolbars
Posted: Sun Jan 07, 2018 6:28 pm
by David Des
Is it possible to create custom toolbars in QCAD?
Re: Custum toolbars
Posted: Sun Jan 07, 2018 8:55 pm
by Husky
Hello David Des - welcome to the QCAD Forum.
David Des wrote:Is it possible to create custom toolbars in QCAD?
QCAD has a lot of options to customize your Interface. If you like to change it e.g. from this ...
- Husky-2018.01.07-03.png (62.56 KiB) Viewed 11124 times
... to this ...
- Husky-2018.01.07-02.png (116.18 KiB) Viewed 11124 times
then there will be nothing in your way to do so.
Re: Custum toolbars
Posted: Sun Jan 07, 2018 9:09 pm
by David Des
Actually I meant a toolbar with specific buttons that I choose for myself.
Re: Custum toolbars
Posted: Sun Jan 07, 2018 9:31 pm
by Husky
David Des wrote:Actually I meant a toolbar with specific buttons that I choose for myself.
The tools in QCAD are organized in themes like "Draw", "Dimensioning", "Modify" etc.
You are able to make a complete Tool bar visible or not visible and you are also able to make single tools on a toolbar visible or not. You have also control over the Button size etc.
But you can't move a tool from one theme to another theme.
To find out if QCAD fits your needs for "customizing" I would recommend to download a trial version and just play around with it.
http://www.qcad.org/de/qcad-downloads-trial
Re: Custum toolbars
Posted: Sun Jan 07, 2018 9:44 pm
by David Des
I do already have the trial version. That is a feature I was used to with AutoCAD at my previous job. I am leaning towards purchasing QCAD anyway because it is so similar to AC. Thanks for the replies.
Re: Custum toolbars
Posted: Sun Jan 07, 2018 9:55 pm
by Husky
You're welcome.
