Custum toolbars
David Des
Custum toolbars
Post by David Des » Sun Jan 07, 2018 6:28 pm
Is it possible to create custom toolbars in QCAD?
Re: Custum toolbars
Post by Husky » Sun Jan 07, 2018 8:55 pm
Hello David Des - welcome to the QCAD Forum.
David Des wrote:Is it possible to create custom toolbars in QCAD?
QCAD has a lot of options to customize your Interface. If you like to change it e.g. from this ...
... to this ...
then there will be nothing in your way to do so. :wink:
David Des
Re: Custum toolbars
Post by David Des » Sun Jan 07, 2018 9:09 pm
Actually I meant a toolbar with specific buttons that I choose for myself.
Re: Custum toolbars
Post by Husky » Sun Jan 07, 2018 9:31 pm
David Des wrote:Actually I meant a toolbar with specific buttons that I choose for myself.
The tools in QCAD are organized in themes like "Draw", "Dimensioning", "Modify" etc.
You are able to make a complete Tool bar visible or not visible and you are also able to make single tools on a toolbar visible or not. You have also control over the Button size etc.
But you can't move a tool from one theme to another theme.
To find out if QCAD fits your needs for "customizing" I would recommend to download a trial version and just play around with it.
http://www.qcad.org/de/qcad-downloads-trial
David Des
Re: Custum toolbars
Post by David Des » Sun Jan 07, 2018 9:44 pm
I do already have the trial version. That is a feature I was used to with AutoCAD at my previous job. I am leaning towards purchasing QCAD anyway because it is so similar to AC. Thanks for the replies.
Re: Custum toolbars
Post by Husky » Sun Jan 07, 2018 9:55 pm
You're welcome.
