PDF Export
kamuthi
PDF Export
Post by kamuthi » Fri Oct 07, 2016 4:58 pm
I wants to save drawings in PDF and dwg file. For this QCad Pro needs to buy or free trial version is enough..?
Re: PDF Upload
Post by Husky » Fri Oct 07, 2016 6:05 pm
kamuthi wrote:I wants to save drawings in PDF and dwg file. For this QCad Pro needs to buy or free trial version is enough..?
You can save a drawing with the free edition as a pdf. Unfortunately dwg is only with the Pro possible.
QCAD Features comparison Free / Pro
http://www.qcad.org/en/qcad-documentation/qcad-features
kamuthi
Re: PDF Upload
Post by kamuthi » Fri Oct 07, 2016 6:09 pm
This PRO is one time buy or yearly renewal..?
Re: PDF Upload
Post by Husky » Fri Oct 07, 2016 6:13 pm
kamuthi wrote:This PRO is one time buy or yearly renewal..?
Yes - one time and you can use it forever.
With the "one time" buy you will also get one year free updates - no additional cost!
http://www.ribbonsoft.com/shop/product. ... roduct=181
kamuthi
Re: PDF Upload
Post by kamuthi » Fri Oct 07, 2016 6:46 pm
whats the difference between QCAD Professional & QCAD/CAM: QCAD Pro + CAM Add-on
Re: PDF Upload
Post by Husky » Fri Oct 07, 2016 7:01 pm
kamuthi wrote:whats the difference between QCAD Professional & QCAD/CAM: QCAD Pro + CAM Add-on
QCAD Pro is used to draw CAD drawings.
The CAD/CAM Version combines the CAD (Computer Aided Design) drawing task with the CAM (Computer-Aided Manufacturing) part for further processing like CNC Maschines. The CAM add-on will produce the code to control/operate processing machines like CNC (Computer Numerical Contro) milling machines etc etc
kamuthi
Re: PDF Upload
Post by kamuthi » Sat Oct 08, 2016 11:02 am
Just made a simple drawing and exported to PDF, but pdf file looks empty.
what may be the reason for this..?
Re: PDF Upload
Post by andrew » Sat Oct 08, 2016 11:06 am
Please refer to our printing and PDF export tutorial at:
http://qcad.org/rsforum/viewtopic.php?f=47&t=3317
kamuthi
Re: PDF Export
Post by kamuthi » Mon Nov 14, 2016 6:01 am
can we select particular portion of the drawing and export as pdf..?
Re: PDF Export
Post by Husky » Mon Nov 14, 2016 6:36 am
You can use the "Print Current View" tool for this purpose. If that isn't what you are looking for please bring us a concrete example. Thanks.
nameispalmer
Re: PDF Export
Post by nameispalmer » Thu May 24, 2018 12:52 pm
You may find this feature through the "Print" option. And that's what I exactly like about QCAD - the most part of the software related to this one still has no way how you're able to export your piece to PDF directly without additional tools. For example, FreeCAD has so, but when I was using it all the documents become corrupted and messy looking when I saved them as PDF, so I fixed them manually via this tool pdffiller DOT com It's a more business-papers-related thing, but works well in order to fix some poor printing issues
