revision cloud?
hangten
revision cloud?
Post by hangten » Fri Jun 05, 2015 4:32 pm
Is there a feature for easily drawing a revision cloud in QCAD.
Design changes in engineering drawings are typically surrounded by a revision cloud. This is a complex line having series of arcs that surrounds the design change.
Re: revision cloud?
Post by andrew » Fri Jun 05, 2015 5:17 pm
No, there is currently no special tool in QCAD for revision clouds.
I've created a feature request at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1224
