Recognize closed contour, calculate area
Hi there,
I'm looking for a program to solve my task as easy as possible and wonder if QCad is the way to go.
What do I want? We are currently doing a ton of GPS measurements where we store different types of areas (lawn, paths, parking place,...) on different layers. This areas are closed contours consisting of polylines, lines and arches. On one layer, e.g. lawn, may be any number of contours. We need the area of each contour on each layer and the summer over the areas on one layer.
I downloaded the trial and this is more or less possible by hand: Turn one layer on and use "Info -> Polygon Area". The problem is, that it is time consuming to compute the area this way. And since this command does not recognizes arches it is not exact.
Thats a rough outline of my problem and perhaps you could outline how you would tackle this problem. As I said we have many such files. I attached an example (with german names, sorry for that...).
What would be nice as first step: If the programm would automatically recognize closed contours and calculate the area. Next step: To script this.
Is this possible? How difficult is it? What are your ideas?
Thanks for your time,
Johannes
Johannes
- 101.dxf
- example
- (53.72 KiB) Downloaded 1063 times
Re: Recognize closed contour, calculate area
Hello Johannes,
I've added a feature request for such a tool at:
http://www.qcad.org/bugtracker/index.ph ... &project=1
This is certainly possible and not very difficult as long as all areas are defined as closed contours (i.e. the boundary of an area consists of entities that connect to (not intersect) each other.ElCattivo wrote:This areas are closed contours consisting of polylines, lines and arches. On one layer, e.g. lawn, may be any number of contours. We need the area of each contour on each layer and the summer over the areas on one layer.
This is essentially a combination of an algorithm to find closed contours which we already have (used as part of other tools) and the polygon area calculation. The algorithm would likely have to interpolate arcs as polylines with small segments (configurable) for the purpose of area calculation since a calculation with real arcs would be non-trivial.ElCattivo wrote:What would be nice as first step: If the programm would automatically recognize closed contours and calculate the area.
Depending on the exact nature and quality of the files, I can imagine a fully automated script that either adds the measured values as text to each area or outputs the results in another, convenient way (text, database, XML, etc). This could be a menu entry in QCAD, a command line tool or both.ElCattivo wrote:Next step: To script this.
Hi there,
this sounds really good.
I found the command "select contour" wich does not seem to work for me. Even though two lines (on the same layer) share the same coordinates for one point only one line gets selected. I attached a file in my first post where I experience this problem. For example turn of all layer but the one called "WEGEFLAECHEN". There is one closed contour that does not get selected. This does not work for any of my contours. Is there something wrong with me or my file!?
If I understand you correctly the calculation of the area of a contour consisting of at least one arc is not possible at the moment (or at least not in a convenient way)? This is the feature request you linked!? Can you estimate when this feature will be implemented?
Thank you for your time,
Johannes
Johannes
Hello ElCattivo,
I have no problems to select the "WEGEFLAECHEN" contour! Maybe you have accidentally locked the Layer - please check the status of the Padlock symbol (black = locked / grey = unlocked).ElCattivo wrote:I attached a file in my first post where I experience this problem. For example turn of all layer but the one called "WEGEFLAECHEN". There is one closed contour that does not get selected. This does not work for any of my contours. Is there something wrong with me or my file!?
I've noticed that the file you have attached contains Z coordinates (3D). While QCAD does import such files, there are several tools that might not work as expected since the coordinates are 3D, but the tools operate on the X/Y plane. This could be easily fixed by flattening the whole drawing, unless you do indeed need the Z coordinates.ElCattivo wrote:I found the command "select contour" wich does not seem to work for me. Even though two lines (on the same layer) share the same coordinates for one point only one line gets selected. I attached a file in my first post where I experience this problem. For example turn of all layer but the one called "WEGEFLAECHEN". There is one closed contour that does not get selected. This does not work for any of my contours. Is there something wrong with me or my file!?
That's correct. In a future tool, arcs would be treated as polylines with small segments to provide a solution.ElCattivo wrote:If I understand you correctly the calculation of the area of a contour consisting of at least one arc is not possible at the moment (or at least not in a convenient way)?
The feature request is for an alternative area measuring tool that computes the area of a closed contour formed by existing entities rather than a polygon entered point by point.ElCattivo wrote:This is the feature request you linked!?
Unfortunately, there are a lot of feature requests and bug reports. I prioritize based on different factors (effort to implement, estimated percentage of users who might profit from a feature, etc.).ElCattivo wrote:Can you estimate when this feature will be implemented?
It is also possible to sponsor new features to prioritize them. Please contact me if you are interested in this. If prioritized, this could be implemented in 2-3 days.
Hi!Husky wrote:Hello ElCattivo,
No, it was not locked (see screenshot). One line gets selected, the rest not...
- Screenshot
- screen.png (175.35 KiB) Viewed 24701 times
Hello and welcome to the forum.
Once selected, try the following tools:
Modify -Explode (to explode any block refs).
Modify - Detect duplicates.
@ElCattivo
Yep - you are right! There are some issues with the contour selection.
Right now I'm only able to explain it with Andrew's note:
andrew wrote:I've noticed that the file you have attached contains Z coordinates (3D). While QCAD does import such files, there are several tools that might not work as expected since the coordinates are 3D, but the tools operate on the X/Y plane. This could be easily fixed by flattening the whole drawing, unless you do indeed need the Z coordinates.
Thank you all four your input.
How do I do that? I will have to discuss wether we can neglect the z-Coordinate.andrew wrote:This could be easily fixed by flattening the whole drawing, unless you do indeed need the Z coordinates.
Yes, presuming the files are being sent to you by someone else, it's probably worth asking them if they can prepare the files as 2D only and as you say neglect the Z coord. This I would think will make things easier to use the files in QCAD!ElCattivo wrote:How do I do that? I will have to discuss wether we can neglect the z-Coordinate.
