entity color to lineweight
dfriasb
Senior Member
Post by dfriasb » Sun Apr 12, 2020 6:01 pm
Hello all,
I'm writing a script in order to set lineweight of all entities that have specific color. I started with "Dark Green" entities; they should be converted to 0.13mm weight:
var document = EAction.getDocument();
var di = EAction.getDocumentInterface();
var entities = document.queryAllEntities();
for (i=0; i<entities.lentgh; i++) {
var entityId = entities[i];
var entity = document.queryEntity(entityId);
var entityColor = entity.getColor();
var entityColorName = entityColor.getName();  // OK til here
if (entityColorName === "Dark Green") {
// set lineweight to 0.13 mm.
entity.setLineweight(-1);
di.applyOperation(op);      } }  // NOT WORKING.
Something is not working in QCAD interface, even in Shell entity lineweight is changed. I tested with
entity.getLineweight()
Any help will be appreciated. Regards,
David
Re: entity color to lineweight
Post by andrew » Tue Apr 14, 2020 9:13 am
Some issues:
- entities.length is misspelled (undefined is casted to 0 in JS)
- the modified entity is never actually added to the operation (op.addOperation)
- you'd want the applyOperation after the for-loop
for (i=0; i<entities.length; i++) {
    var entityColorName = entityColor.name();  // Use name (Qt API, always english), not getName (localised)
    if (entityColorName === "#008000") {  // name / code returned by QColor::name() for dark green
        // set lineweight to ByLayer (?)
        entity.setLineweight(RLineweight.WeightByLayer);
    op.addObject(entity, false);
