I know how to use different thickness for different layers. But in my case qcad does not respond to this change. As you can see in this image http://www.bilder-upload.eu/show.php?fi ... 341089.png, I am using different color and line thickness (0.5 mm, 1.0 mm, 2.0 mm) for the three layers shown, but only colors are changing. Line thickness remains unchanged. The three entities have been drawn in different layers.
Any suggestion will be appreciated.
Line thickness does not change
- Junior Member
Re: Line thickness does not change
mmasrooralimmasroorali wrote:I know how to use different thickness for different layers. But in my case qcad does not respond to this change. As you can see in this image http://www.bilder-upload.eu/show.php?fi ... 341089.png, I am using different color and line thickness (0.5 mm, 1.0 mm, 2.0 mm) for the three layers shown, but only colors are changing. Line thickness remains unchanged. The three entities have been drawn in different layers.
Not sure about CE version but with the pro versions -no problem!
- Junior Member
