dxf->writeHatch, but how ?
Use this forum to ask questions about how to do things in dxflib.
Postby bonsalty » Wed Jun 10, 2009 10:12 am
I havent found how to write a hatch into dxf
We have:
void DL_Dxf::writeHatch1 ( DL_WriterA & dw,
const DL_HatchData & data,
const DL_Attributes & attrib
where DL_HatchData (int hNumLoops, bool hSolid, double hScale, double hAngle, const string &hPattern)
First question: what shoud hPattern be and whats this hNumLoops all about?
Second question:
If I call :
void DL_Dxf::writeHatchLoop1 ( DL_WriterA & dw,
const DL_HatchLoopData & data
should I call the writeHatchEdge functions after this or before the writeHatchLoop?
Third question,why must I call writeHatch2 and how to use it ????
An example would be nice,since its impossible to decode it from the ribbonsofts class reference. Thank you!
bonsalty
Postby andrew » Wed Jun 10, 2009 2:11 pm
works, but not everything...
Postby bonsalty » Wed Jun 10, 2009 7:27 pm
Thanks I managed to use it. I inserted a single loop with 3 edges(a triangle :) ) and succeded to make a triangle with hatch.
But pattern name is still a mistery.
I tried "EARTH", "ANSI31",... default pattern names,but nothing happens. However I can see that names in autocad when I click on my hatchobject, but it doesnt change the hatch style?!
I tried rotate and scale property too,they doesnt work either. Its always a 45 degree hatch.The solid property works fine.
bonsalty
Return to dxflib 'How Do I' Questions
Who is online
Users browsing this forum: No registered users and 0 guests
