QCad 2.1.3.0 doesn't print on K/Ubuntu 7.04
Postby The Punisher » Wed May 02, 2007 10:17 pm
Theree weeks ago I have bought Qcad 2.1.3.0 using it with K/Ubuntu 6.10.
All worked great.
I have now updated my computer to K/Ubuntu 7.04 and Qcad doesn't print anymore.
My two printers are not listed as available on print dialog; an empty bar is present.
All other KDE programs are printing regularly.
Please help, I need to print
Your faithfully
Max
The Punisher
Re: QCad 2.1.3.0 doesn't print on K/Ubuntu 7.04
Postby andrew » Wed May 02, 2007 10:34 pm
The Punisher wrote:Theree weeks ago I have bought Qcad 2.1.3.0 using it with K/Ubuntu 6.10.
All worked great.
Your faithfully
Max
As an immediate workaround, you might want to generate a PDF from your drawing instead (File - PDF Export) and then print the PDF using acrobat or kpdf. This gives you an equally good result.
For a fix, there has been some talk on the mailing list about this:
http://tech.groups.yahoo.com/group/qcad-user/message/1821
Return to QCAD 2.1/2.2 Troubleshooting and Problems
Who is online
Users browsing this forum: No registered users and 1 guest
cron
