bobleelsker wrote:Hello.
I have been using QCAD demo for a while with no problems, and purchased it yesterday. Removed the demo, downloaded and installed my copy of the program. I sometimes have problem with opening and saving files. The program locks up, and I have no other options than to close the program, and try again.
I am running Vista ultimate as OS.
There was no problem with opening and saving files in the demo. Anyone come with an idea..
I have the same problem with Windows XP : no problems with demo, problems for openning files with "professional for windows" version. I found that the problem occurs when I use the left part of the windows : When I select "my computer" and after select "documents and setting/my name". If I select directly "documents and setting/my name" on the left side or no used the left side on the windows, il seams that it runs correctly (I got it this afternoon only, so I haven't lot of feed-back.
I try to reset QCAD like it is written on this forum for quite similar problems, but it change nothing for me.
Bye
