edi wrote:OK, here is some new data along with things I don't understand. All data gathered with my HP 430.
1. Setting the paper and using the print preview doesn't seem to affect the CAM export in any way.
** Printing and Cam export are two different issues.
I could post pictures if this sounds interesting to anybody but me.
**The dxf file might help.
Are you using Windows, what version?
Do you have the updated driver for your hp430:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=pl-7408-7&jumpid=reg_R1002_USEN
Also Windows, in Printer Settings, under File, under Server properties, you can define custom paper sizes. You can also change the standard sizes, so when tabloid is selected it would configure to what you have it set to.
Camexpert hp cam outout is HPGL, your raster plotter uses HPGL/2.
The Roland plotter drivers are free to download and one may work with your plotter.
Roland Plotter Drivers:
http://www.rolanddg.com/download.html
Using a serial-parallel converter eliminates many problems with using the serial port for printing on the newer computers. Many new machines do not even have serial ports. In Linux the converter works straight away.
I use a HP7550A plotter and a HPDeskjet1220C with Camexpert with no problems in Windows and Linux. After things are set up paper sizes are not a problem.
