Would it be possible to size dimension text, offsets, etc., by layer rather across an entire drawing? An adjustable drawing-wide default set would be great, but overrides or a scale factor per layer would be a big boost. I use QCad to draw everything from small pins up to an entire (at the risk of overstating matters) an entire machine/device/enclosure. Sizes vary by a factor of ten, sometimes more, making one text size restrictive.
Bill
