Line thickness does not change
Use this forum to ask questions about how to do things in the QCAD Community Edition.
Postby mmasroorali » Sat Mar 10, 2012 1:59 am
I know how to use different thickness for different layers. But in my case qcad does not respond to this change. As you can see in this image http://www.bilder-upload.eu/show.php?file=8bdadc-1331341089.png, I am using different color and line thickness (0.5 mm, 1.0 mm, 2.0 mm) for the three layers shown, but only colors are changing. Line thickness remains unchanged. The three entities have been drawn in different layers.
Any suggestion will be appreciated.
mmasroorali
Re: Line thickness does not change
Postby clive » Sat Mar 10, 2012 6:34 pm
mmasroorali wrote:I know how to use different thickness for different layers. But in my case qcad does not respond to this change. As you can see in this image http://www.bilder-upload.eu/show.php?file=8bdadc-1331341089.png, I am using different color and line thickness (0.5 mm, 1.0 mm, 2.0 mm) for the three layers shown, but only colors are changing. Line thickness remains unchanged. The three entities have been drawn in different layers.
mmasroorali
Not sure about CE version but with the pro versions -no problem!
clive
Postby mmasroorali » Sun Mar 11, 2012 1:05 am
Does that mean it has only to do with versions? Yes, I am using the CE version.
mmasroorali
Postby clive » Sun Mar 11, 2012 1:31 pm
mmasroorali wrote:Does that mean it has only to do with versions? Yes, I am using the CE version.
Maybe!
I don`t use the community version.
clive
Return to QCAD Community 'How Do I' Questions
