How do I read drawing extents
Use this forum to ask questions about how to do things in dxflib.
Postby dgp » Wed Nov 10, 2010 2:51 pm
Hi,I have a dxf file with the below extents in the header section.
How do I read them using dxflib ?
$LIMMIN
10
-122.3180704378
20
47.4300256966
9
$LIMMAX
10
-122.3078004390
20
47.4643399154
dgp
Postby andrew » Wed Nov 10, 2010 8:39 pm
The DXF parser calls the setVariableVector, setVariableString, setVariableInt or setVariableDouble functions of your DL_CreationInterface implementation for each such header variable that is found.
Postby dgp » Thu Nov 11, 2010 6:34 am
This is my header section in dxf file
0
SECTION
2
HEADER
9
$ACADVER
1
AC1009
9
$LUNITS
70
2
9
$LIMMIN
10
-122.3180704378
20
47.4300256966
9
$LIMMAX
10
-122.3078004390
20
47.4643399154
9
$EXTMIN
10
-122.3180704378
20
47.4300256966
9
$EXTMAX
10
-122.3078004390
20
47.4643399154
999
After using the following function int example dxflib_test shipped with dxflib ,it gives
Key#$ACADVER ,Value#AC1009 , Code# 1
void Test_CreationClass::setVariableString(const char*key , const char*value, int code)
    printf("\n\n\n\t Key#%s ,Value#%s , Code# %d\n",key,value, code
   // printAttributes();
Is there a way to get values from $LIMMIN and $LIMMAX
dgp
Postby andrew » Thu Nov 11, 2010 9:00 am
For $LIMMIN / $LIMMAX you are not looking for a string but vector (setVariableVector).
Postby dgp » Thu Nov 11, 2010 10:30 am
Thank you :D .I got the dxf boundaries now.
void Test_CreationClass::setVariableVector(const char* key,double v1, double v2, double v3, int code)
printf("\n\n\n\t Key#%s ,v1#%f , v2#%f,v3#%f\n",key,v1, v2,v3,code);
dgp
Return to dxflib 'How Do I' Questions
cron
