by John.Drabik » Wed May 12, 2010 4:53 am
To copy and paste one or more "things" do the following:
1) suggest you Deselect everything (Select -> Deselect All)
2) from the left menu, choose one of the selection tools, for example, Select Entities
3) select one (or more) things
4) press the Copy icon on the toolbar (or press CTRL-C)
5) QCad now prompts you for a reference *relative* to the items to be copied; for example, if you are copying a line, you may want the left end of the line to be the "hot" end
You can now do whatever you wish. When it comes time to paste, do:
1) press the Paste button (or press CTRL-V)
2) QCad now prompts again for a "reference" point; this is actual the point where you want to place the "hot" point you selected previously, such as the left end of a line, or somewhere among a group of items
3) steps 1 and 2 of this (paste) section can be repeated as often as desired
DO NOT follow the PDF Users Guide, which talks about right-clicking on the toolbar for example. It doesn't work. Also, you may find it helpful to watch for the bold black arrows in the left-side "menus". These indicate when you can move to the next stage (the lower arrow, pointing ---> ) or go back to a previous menu (the <---- arrow).
