I am probably doing something seriously wrong but I can't get the dimension lines to show numbers.
Maybe I simply am using the wrong command.
I am a total newbie to the product so please be kind.
Dimension lines not showing numbers
Please refer to the FAQ at:
http://www.ribbonsoft.com/qcad_doc_faq.html#13
-> 13. I can create dimensions but they show no label.
- Registered Member
Hi, I have the same problem, and worked out that it was too small to see, but when I go into the relevant screen to fix it, I can't make the dimensions text more than 5mm. It won't let me type in any other number than what appears in the dropdown.
I am drawing a car chassis in real world dimensions (3000mm * 1500mm approx) and when I print the diagram on A4 I can't read the dimensions.
What am I missing?
Great product by the way, loving using it.
What am I missing?
- Registered Member
OK, this is where I apologise! I am using the community version on Ubuntu 8.04. I realise now that I should have posted there, but as this thread was going I thought I'd tag on to the end.andrew wrote:This is odd. You should be able to type any number in that field.glovermini wrote:I can't make the dimensions text more than 5mm. It won't let me type in any other number than what appears in the dropdown.
What version of QCAD are you using and on what exact operating system?
Sounds like I need to buy the book and a full version!
