tool: middle of a segment
Please use this forum to post feedback and suggestions related to QCAD Professional.
Postby michel » Mon May 12, 2008 4:23 pm
Hello Andrew,
What do you think about a snap possibility to the middle of a segment?
Michel
michel
Postby ttrw » Mon May 19, 2008 8:35 pm
Hi Michel.
Such a tool already exists! Under 'snap', choose 'middle'. (command line; sm).
Hope that helps :)
Tom
ttrw
Postby michel » Wed May 21, 2008 5:50 am
Hello ttrw,
I kbow that the tool you mentioned exists, it gives you the middle of a line. So far it's correct.
But what i meant is a tool which gives you the middle of the segment or segments within a line. As long as you move with the cursor along the line this option should enable to find always the middle of the segment on which you move along.
Michel
michel
Return to QCAD 2.1/2.2 Suggestions and Feedback
cron
