There is a folder called "_META" in the Parts Library and it contains just one file called "meta.rdf". Anybody know the purpose of this folder and file. It sits at the top of the list of library folders. Does that mean it is expected to be used often?
Can it be deleted? Or will that break the library structure?
Purpose and Deleat-ability of _META Folder in Parts Library
- Chips&Chips
- Full Member
Paul A.
SE Texas
Windows 10
QCAD V 3.29.3.0
SE Texas
Windows 10
QCAD V 3.29.3.0
Re: Purpose and Deleat-ability of _META Folder in Parts Library
Purpose:
https://qcad.org/rsforum/viewtopic.php? ... 6352#p6352
If you want to keep or delete those is mostly up to you.
Remind that sharing technologies requires to list licences.
