Comandlinemenu
Cactuslock
Comandlinemenu
Post by Cactuslock » Wed Sep 13, 2023 5:23 am
I get this command on bottom. I see a arrow inside of a television symbol attached to a 6 inch block. I open other drawings and it stays I close program and it returns,
Re: Comandlinemenu
Post by CVH » Wed Sep 13, 2023 6:24 am
Cactuslock,
Please see forum rules above:
- Always indicate your operating system and QCAD version.
- Attach screenshot.
Looks like the idle state of the Options Toolbar but I can not associate that with what you call a "6 inch block".
"COMANDLINEMENU" lets me think about a menu item for the Command Line but I can not locate "commandlinemenu" textual in QCAD sources.
With or without the double 'm', case-insensitive.
In a standard installation the Command Line widget is usually at the bottom, below the drawing panel.
The Options Toolbar is usually above the drawing panel.
But both can be moved to a custom location or set floating.
If it is still visible when you close QCAD then I think it is not related to QCAD.
You might want to reset your QCAD configuration:
Return to “Chat”
