new user
Use this forum to ask questions about how to do things in QCAD 3.0.
new user
Postby Patmatt41 » Thu Feb 09, 2012 3:12 pm
I'm a new user of :oops:
Version:
3.0 RC3
I need Help for Print settings :?:
I Want Ajust the plott in A4 Format
Can I count on your help
Pat from France
Patmatt41
Re: new user
Postby clive » Thu Feb 09, 2012 4:12 pm
Patmatt41 wrote:Hello,
Version:
3.0 RC3
Pat from France
Hi and welcome Patmatt41
To set your "print page" size.
For "Current" drawing (will apply to current drawing only)
1. Edit > Drawing preferences > printing > page.
2.From here -you can set the print page settings, size, orientation etc.
For the "Application default" print settings (will apply to all new
drawings)
1.Edit > Application preferences > printing >Default page settings.
2.From here you can set the Default print page settings -size,orientation etc.
In Print preview -file > print preview or use Icon or Ctrl-Shift-P
There are options to set the scale, move the paper position, orientation, auto-fit to page...etc. etc...
Hope this helps :wink:
You can use the sub -forums QCAD Professional (3.0) How do I questions or Troubleshooting and problems for similar questions.
clive
Postby Patmatt41 » Thu Feb 09, 2012 4:52 pm
Tanks a lot Clive for this super quick answer.
I've see the options in
"1. Edit > Drawing preferences > printing > page.
2.From here -you can set the print page settings, size, orientation etc."
but I don't found the options in Preview to
"...to set the scale, move the paper position, orientation, auto-fit to page...etc. etc... "
:roll:
how can i find the "... sub -forums QCAD Professional (3.0) How do I questions or Troubleshooting and problems for similar questions.
Tanks :(
Patmatt41
Postby clive » Thu Feb 09, 2012 5:03 pm
Patmatt41 wrote:Tanks a lot Clive for this super quick answer.
:roll:
Tanks :(
For "Print preview" -either
1. File > print preview.
2. Using keyboard -press "Ctrl-Shift_P".
3. Or click on "Print preview" icon in "Top" tool bar (printer icon next to SVG icon).
The options are found above in the "docked" toolbar!
To find the sub-forums just scroll down the main forum page -they are under QCAD professinal (3.0)
clive
Postby Patmatt41 » Fri Feb 10, 2012 10:50 am
thank you again
I must absolutely go to My ophthalmologist
I did not see the toolbar
:shock:
Patmatt41
Postby clive » Fri Feb 10, 2012 12:59 pm
Patmatt41 wrote:thank you again
:shock:
:lol: No problem patmatt41, enjoy QCAD
clive
Re: new user
Postby huyandhang » Sun Jul 01, 2012 4:09 am
I also have such problems so thank for all share!
huyandhang
Return to QCAD 3.0 'How Do I' Questions
