[solved] How to move Dimension text
lenwinn
Post by lenwinn » Mon May 28, 2018 12:42 am
When dimensioning circles the text defaults to a mid position over the arrows. Is there a way to extend the leader to allow the text to be placed in clear space ?
Re: How to move Dimension text
Post by Husky » Mon May 28, 2018 5:24 am
No but you can move the dimension text manually. To do so select the dimension. You'll see blue reference points - one is located in the middle of the dim text. Use this reference point with your mouse to Drag and drop the text to a more convenient location.
lenwinn
Post by lenwinn » Mon May 28, 2018 2:20 pm
Thanks Husky
