Keyboard doesn't work....
Michele666
Post by Michele666 » Sat Oct 21, 2017 4:22 pm
I just installed v3.18 on Linux Mint Sonya 18.2 64 bit....but when I run the program, my keyboard (all my keyboard) doesn't work...
I also followed instruction on this thread, but with no success...
https://qcad.org/rsforum/viewtopic.php? ... ard#p18835
Can you please help?
Re: Keyboard doesn't work....
Post by andrew » Mon Oct 23, 2017 9:20 am
Thanks for your report.
Please indicate the QCAD Edition you are using (QCAD Professional, QCAD Trial-Version, QCAD Community Edition).
Please indicate which package you have downloaded and installed (qcad-3.18.1-pro-linux-x86_64.run or qcad-3.18.1-pro-linux-qt4-x86_64.run). You might want to try the alternative of the two packages.
Post by andrew » Mon Oct 23, 2017 10:05 am
Quick update: I cannot reproduce this problem here with either package on Linux Mint 18.2 64bit. Both packages seem to work just fine here.
Michele666
Post by Michele666 » Tue Oct 24, 2017 3:03 am
  • QCAD Community Edition
    Version:
    3.18.1.0 (3.18.1)
    Internet:
    QCAD.org
    Build Date:
    Oct 4 2017
    Revision:
    24e23aa
    Qt Version:
    5.8.0
    Architecture:
    x86_64
    Compiler:
    gcc 4.8.1
so you think the problem is related only on my laptop ASUS N552vW?
Post by Husky » Tue Oct 24, 2017 7:57 am
Hi Michele666,
Was that a QCAD Trial Version - downloaded from this site: http://www.qcad.org/de/qcad-downloads-trial and you removed the trial option?
Was that the archive or the installation packet?
Your laptop system is a 64 bit and not a 32 bit system, correct?
Did you a single installation in an empty Subdirectory and has not mixed multiple QCAD installations in the same directory?
Michele666
Post by Michele666 » Tue Oct 24, 2017 8:04 pm
Yes it was downloaded from that page.
the archive it was the onstallation package
no other installation.
this is the folder where the program is installed
&Home//opt/qcad-3.18.1-trial-linux-x86_6
Post by Husky » Wed Oct 25, 2017 3:18 am
I think we had just two cases like this. The first one was solved (likely by accident) but you told us that you tried the same steps and it wasn't working. Ok, I have to admit that I'm fishing in muddy water .... :(
May I ask you again so that we get a better picture:
1.
... no other program on the same system has this Keyboard problem
... the Mouse is proper working,
... you are not using a drawing which isn't designed by QCAD for your test, correct?
Michele666 wrote:... my keyboard (all my keyboard) doesn't work...
2. What means "all my keyboard"? Means that that you are not even able to put text in the "Text" tool dialog?
3. What about the Center, Radius tool - you are able to fill the Radius field in the Option box?
4. ... or does "all my Keyboard" means that you are not able to use commands in the Command Line
5. The Keyboard isn't locked by accident. Maybe some kind of Key which works like a caps lock or num lock
6. Have you tried to run QCAD on a Thump drive attached to this Laptop? If not use the .gz version for a test.
Michele666
Post by Michele666 » Wed Oct 25, 2017 5:35 pm
Hi and thanks,
1.
...no
...yes at all LMB & RMB & WHEEL
....no
I can't type any text in the dialog box
Not at all
I can't type anything
I tested to open a text file while QCAD is running and I've been able to properly write on the text file, but when I tried to write on QCAD (command line e.g.) I couldn't type anything.
What is a Thump?Is it a sort of live distribution as like linux does? an installation on a USB? can you provide a link?
Post by andrew » Wed Oct 25, 2017 6:07 pm
You might want to try the legacy package using Qt 4 and older libraries:
http://qcad.org/en/qcad-downloads-trial
-> All Downloads
-> Linux 64bit Qt 4 Installer
Direct link:
http://qcad.org/archives/qcad/qcad-3.18 ... x86_64.run
Post by Husky » Wed Oct 25, 2017 7:50 pm
Thank you for this information!
Michele666 wrote: What is a Thump?Is it a sort of live distribution as like linux does? an installation on a USB? can you provide a link?
Sorry, that was a typo! I meant Thumb drive. That is a USB flash drive. Also called USB drive, USB stick, pen drive, jump drive, disk key, disk on key, flash-drive, memory stick, USB memory ...
Source: https://www.wikiwand.com/en/USB_flash_drive
... I shouldn't answer in the middle of the night. :shock:
Michele666
[SOLVED] Keyboard doesn't work....
Post by Michele666 » Sat Oct 28, 2017 1:15 am
after installing the qt4 version it worked.
Just a last question: what is the difference between the 2 versions? only the QT4 libraries?
Thanks for the support & regards.
Re: [SOLVED] Keyboard doesn't work....
Post by Husky » Sat Oct 28, 2017 5:14 am
Michele666 wrote:Hi,
Glad to hear that.
Michele666 wrote:... what is the difference between the 2 versions? only the QT4 libraries?
It has the same Release No. - should have the same features.
Michele666 wrote:Thanks for the support & regards.
You are welcome!
