Step 4 from Compiling QCAD from Sources on Linux was completed after I added the command sudo make install in Step 3 (after the make command).
Now, in Step 5, I have a new error:
make[4]: Entering directory '/home/radu/qcad/src/3rdparty/spatialindexnavel'
rm -f libspatialindexnavel.so
g++ -Wl,-O1 -Wl,-rpath,/usr/local/Trolltech/Qt-4.8.6/lib -shared -o libspatialindexnavel.so release/BulkLoader.o release/Index.o release/Leaf.o release/Node.o release/RTree.o release/Statistics.o release/LineSegment.o release/MovingPoint.o release/MovingRegion.o release/Point.o release/Region.o release/SpatialIndexImpl.o release/TimePoint.o release/TimeRegion.o release/Buffer.o release/DiskStorageManager.o release/MemoryStorageManager.o release/RandomEvictionsBuffer.o release/rand48.o release/Tools.o -L/usr/local/Trolltech/Qt-4.8.6/lib -L/usr/X11R6/lib -L/home/radu/qcad/release -lQtWebKit -L/usr/local/Trolltech/Qt-4.8.6/lib -lQtScriptTools -lQtScript -L/usr/X11R6/lib -lQtSvg -lQtXmlPatterns -lQtOpenGL -lQtUiTools -L/home/radu/qt-everywhere-opensource-src-4.8.6/lib -lQtXml -lGL -lQtDesigner -lQtHelp -lQtSql -lQtGui -lQtNetwork -lQtCore -lpthread
/usr/bin/ld: cannot find -lQtWebKit
/usr/bin/ld: cannot find -lQtXmlPatterns
collect2: error: ld returned 1 exit status
Makefile.Release:148: recipe for target '../../../release/libspatialindexnavel.so' failed
Do you know what is this error?
Thank you.
