Disappearing bitmaps
dajqcad
Post by dajqcad » Thu Jul 10, 2014 7:54 pm
I am currently using version 3.5 and am having problems with imported bitmaps. Every time I save and close a drawing that has a bitmap added to it the bitmap disappears when the drawing is reopened. The bitmap being used is a standard jpeg which behaves properly when installed - can be moved, rotated and scaled - but as soon as I close and save it vanishes. Am I doing something wrong or is this a bug? Am I using the wrong format - would simple .bmp or tiff files do better?
I am using QCAD on an iMac with Mavericks v.10.9.4 installed.
Re: Disappearing bitmaps
Post by andrew » Thu Jul 10, 2014 8:57 pm
Thanks for your report.
Could you attach the drawing file (DXF) and bitmap file you are using or send it to me via private message or e-mail if it is private? Thanks.
Post by andrew » Mon Jul 14, 2014 8:46 am
Thanks for the file.
I've moved this topic to the appropriate forum for QCAD Community Edition users.
The bug report is at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1073
