QCAD/CAM Trial
phill
QCAD/CAM Trial
Post by phill » Thu Nov 19, 2015 4:30 am
Is QCAD/CAM available as a trial on QCAD3 Professional, if so how do I get/activate the trial.
Cheers, Phill.
Re: QCAD/CAM Trial
Post by andrew » Thu Nov 19, 2015 9:56 am
The QCAD/CAM trial is included in the packages you can download from our web site at:
http://www.qcad.org/en/qcad-downloads-trial
If you already have QCAD Professional installed, you can install the QCAD/CAM trial version in parallel, into a separate directory.
phill
Re: QCAD/CAM Trial
Post by phill » Thu Nov 19, 2015 10:09 am
Thanks for that, I do have QCAD Professional installed and I was wanting to check out the CAM side of things.
Return to “QCAD/CAM”
