Custom order for export
Post by andrew » Wed Jul 29, 2015 9:41 am
From a QCAD/CAM user:
Can I control the order in which entities are exported in any other way than the predefined ways?
Re: Custom order for export
Post by andrew » Wed Jul 29, 2015 9:42 am
It is possible to overwrite exportEntities to define any desired custom order in which entities are exported.
The simplest implementation would be (random order):
MyClass.prototype.exportEntities = function() {
    var ids = this.document.queryAllEntities();
    for (var i = 0; i < ids.length; ++i) {
        var entityId = ids;
        var entity = this.document.queryEntity(entityId);
        this.exportContourEntity(entity.data());
Return to “QCAD/CAM”
