Qcad Professional, Ubuntu Install and icon
Postby gandalf » Sun Aug 02, 2009 12:55 pm
Where do I find a qcad icon to link to in the desktop? Can't seem to find the icon file in the install directory.
gandalf
Re: Qcad Professional, Ubuntu Install and icon
Postby LuisC-SM » Wed Aug 26, 2009 4:37 pm
gandalf wrote:Where do I find a qcad icon to link to in the desktop? Can't seem to find the icon file in the install directory.
LuisC-SM
SVG version
Postby user4096 » Wed Jan 12, 2011 12:22 am
I created an Inkscape Scalable Vector Graphic (.svg) file, based on PNG samples of the icon I found here (32x32 px) and elsewhere (64x64 px). The two PNG images don't match, as one is rather flat and the other appears to have been created with a kind of 3D shading effect. Anyhow, my SVG version is a starting point for anyone who wants to fix it up and make it fancier. The advantage of Inkscape is that it can generate PNG exports of vector images in almost any desired size, and once the appropriate PNG image is created, there are a number of programs that can be used to convert the raster image to other popular icon file formats. The GNOME desktop environment in Linux can use SVG files as icons directly, allowing them to be stretched at will on the desktop, without loss of image resolution.
This forum evidently doesn't allow file attachments, so you'll need to copy the following XML code into a plain-text editor and save the file as "qcad.svg", or similar. :wink:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!-- Generator: Adobe Illustrator 9.0, SVG Export Plug-In  -->
<svg
   xmlns:dc="http://purl.org/dc/elements/1.1/"
   xmlns:cc="http://creativecommons.org/ns#"
   xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
   xmlns:svg="http://www.w3.org/2000/svg"
   xmlns="http://www.w3.org/2000/svg"
   xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
   xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
   width="586.17627pt"
   height="586.141113pt"
   viewBox="0 0 586.17627 586.141113"
   xml:space="preserve"
   id="svg2"
   version="1.1"
   inkscape:version="0.47 r22583"
   sodipodi:docname="qcad.svg"
   inkscape:export-filename="/home/sysop/.icons/qcad_64px_new-test.png"
   inkscape:export-xdpi="7.8212404"
   inkscape:export-ydpi="7.8212404"><metadata
   id="metadata73"><rdf:RDF><cc:Work
       rdf:about=""><dc:format>image/svg+xml</dc:format><dc:type
         rdf:resource="http://purl.org/dc/dcmitype/StillImage" /><dc:title></dc:title></cc:Work></rdf:RDF></metadata><defs
   id="defs71"><inkscape:perspective
   sodipodi:type="inkscape:persp3d"
   inkscape:vp_x="0 : 366.3382 : 1"
   inkscape:vp_y="0 : 1000 : 0"
   inkscape:vp_z="732.72034 : 366.3382 : 1"
   inkscape:persp3d-origin="366.36017 : 244.22546 : 1"
   id="perspective75" />
   id="perspective3821"
   inkscape:persp3d-origin="0.5 : 0.33333333 : 1"
   inkscape:vp_z="1 : 0.5 : 1"
   inkscape:vp_x="0 : 0.5 : 1"
   sodipodi:type="inkscape:persp3d" /></defs><sodipodi:namedview
   pagecolor="#ffffff"
   bordercolor="#666666"
   borderopacity="1"
   objecttolerance="10"
   gridtolerance="10"
   guidetolerance="10"
   inkscape:pageopacity="0"
   inkscape:pageshadow="2"
   inkscape:window-width="1024"
   inkscape:window-height="689"
   id="namedview69"
   showgrid="false"
   showborder="false"
   inkscape:zoom="0.6354758"
   inkscape:cx="321.2593"
   inkscape:cy="366.33789"
   inkscape:window-x="0"
   inkscape:window-y="27"
   inkscape:window-maximized="1"
   inkscape:current-layer="svg2" />
   <g
   style="fill:none;stroke:#00ffff;stroke-width:0.17638899;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4"
   id="g7">
         <path
   id="path9"
   d="m 0.15918,502.34424 c 0,0.0195 -0.016113,0.0351 -0.035645,0.0351 -0.019532,0 -0.035156,-0.0156 -0.035156,-0.0351 0,-0.0195 0.015625,-0.0352 0.035156,-0.0352 0.019531,0 0.035645,0.0156 0.035645,0.0352 z" />
      </g><g
   id="g11">
         <path
   id="path13"
   d="m 0.15918,418.63428 c 0,0.0195 -0.016113,0.0361 -0.035645,0.0361 -0.019532,0 -0.035156,-0.0166 -0.035156,-0.0361 0,-0.0186 0.015625,-0.0352 0.035156,-0.0352 0.019531,0 0.035645,0.0166 0.035645,0.0352 z" />
      </g><g
   id="g15">
         <path
   id="path17"
   d="m 0.15918,334.92529 c 0,0.0195 -0.016113,0.0352 -0.035645,0.0352 -0.019532,0 -0.035156,-0.0156 -0.035156,-0.0352 0,-0.0195 0.015625,-0.0352 0.035156,-0.0352 0.019531,0 0.035645,0.0156 0.035645,0.0352 z" />
      </g><g
   id="g19">
         <path
   id="path21"
   d="m 0.15918,251.21631 c 0,0.0195 -0.016113,0.0352 -0.035645,0.0352 -0.019532,0 -0.035156,-0.0156 -0.035156,-0.0352 0,-0.0195 0.015625,-0.0352 0.035156,-0.0352 0.019531,0 0.035645,0.0156 0.035645,0.0352 z" />
      </g><g
   id="g23">
         <path
   id="path25"
   d="m 0.15918,167.50684 c 0,0.0195 -0.016113,0.0356 -0.035645,0.0356 -0.019532,0 -0.035156,-0.0161 -0.035156,-0.0356 0,-0.0191 0.015625,-0.0352 0.035156,-0.0352 0.019531,0 0.035645,0.0161 0.035645,0.0352 z" />
      </g><g
   id="g27">
         <path
   id="path29"
   d="m 0.15918,83.797852 c 0,0.01904 -0.016113,0.03516 -0.035645,0.03516 -0.019532,0 -0.035156,-0.01611 -0.035156,-0.03516 0,-0.01953 0.015625,-0.03516 0.035156,-0.03516 0.019531,0 0.035645,0.01562 0.035645,0.03516 z" />
      </g><g
   id="g2912"
   style="stroke:#000000;stroke-opacity:1;stroke-width:4.8;stroke-miterlimit:4;stroke-dasharray:none"><path
     d="M 0.123535,586.05322 V 0.088379"
     id="path5"
     style="fill:none;stroke:#000000;stroke-width:4.8;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-opacity:1;stroke-dasharray:none" /><path
     d="M 83.833008,586.05322 V 0.088379"
     id="path31"
     d="M 167.54199,586.05322 V 0.088379"
     id="path33"
     d="M 251.25146,586.05322 V 0.088379"
     id="path35"
     d="M 334.96045,586.05322 V 0.088379"
     id="path37"
     d="M 418.67041,586.05322 V 0.088379"
     id="path39"
     d="M 502.37939,586.05322 V 0.088379"
     id="path41"
     d="M 586.08838,586.05322 V 0.088379"
     id="path43"
     d="M 0.123535,586.05322 H 586.08838"
     id="path45"
     d="M 0.123535,502.34424 H 586.08838"
     id="path47"
     d="M 0.123535,418.63428 H 586.08838"
     id="path49"
     d="M 0.123535,334.92529 H 586.08838"
     id="path51"
     d="M 0.123535,251.21631 H 586.08838"
     id="path53"
     d="M 0.123535,167.50684 H 586.08838"
     id="path55"
     d="M 0.123535,83.797852 H 586.08838"
     id="path57"
     d="M 0.123535,0.088379 H 586.08838"
     id="path59"
     style="fill:none;stroke:#000000;stroke-width:4.8;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-opacity:1;stroke-dasharray:none" /></g>
   <g
   id="_x0030_"
   style="fill-rule:nonzero;clip-rule:nonzero;stroke:#000000;stroke-miterlimit:4;">
   </g>
   <g
   id="Layer_x0020_1"
   </g>
<path
   style="font-size:medium;font-style:normal;font-variant:normal;font-weight:normal;font-stretch:normal;text-indent:0;text-align:start;text-decoration:none;line-height:normal;letter-spacing:normal;word-spacing:normal;text-transform:none;direction:ltr;block-progression:tb;writing-mode:lr-tb;text-anchor:start;color:#000000;fill:none;fill-opacity:1;stroke:none;stroke-width:1.60000001999999997;marker:none;visibility:visible;display:inline;overflow:visible;enable-background:accumulate;font-family:Bitstream Vera Sans;-inkscape-font-specification:Bitstream Vera Sans"
   d="m 293.09375,67.96875 c 115.14577,0 208.5,93.32249 208.5,208.46875 0,115.14528 -93.35424,208.46875 -208.5,208.46875 -115.14577,0 -208.46875,-93.32347 -208.46875,-208.46875 0,-115.14626 93.32297,-208.46875 208.46875,-208.46875 z"
   id="path3702" /><path
   d="m 219.125,173.03125 a 0.80008001,0.80008001 0 0 0 -0.71875,0.8125 l 0,205.1875 a 0.80008001,0.80008001 0 0 0 0.78125,0.8125 l 147.84375,0 a 0.80008001,0.80008001 0 0 0 0.78125,-0.8125 l 0,-205.1875 a 0.80008001,0.80008001 0 0 0 -0.78125,-0.8125 l -147.84375,0 a 0.80008001,0.80008001 0 0 0 -0.0625,0 z"
   id="path3721" /><path
   style="fill:#d2d3e6;fill-opacity:1;stroke:#000000;stroke-width:1.60000001999999997;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-opacity:1;stroke-dasharray:none"
   id="path61"
   d="m 489.8227,266.40349 c 0,-115.57861 -93.69531,-209.273436 -209.27343,-209.273436 -115.57813,0 -209.272951,93.694826 -209.272951,209.273436 0,115.57764 93.694821,209.27295 209.272951,209.27295 115.57812,0 209.27343,-93.69531 209.27343,-209.27295 z" /><path
   sodipodi:type="arc"
   style="fill:#ffffff;fill-opacity:1;fill-rule:evenodd;stroke:none"
   id="path3827"
   sodipodi:cx="469.72678"
   sodipodi:cy="414.01752"
   sodipodi:rx="225.81505"
   sodipodi:ry="222.6678"
   d="m 695.54182,414.01752 a 225.81505,222.6678 0 1 1 -451.63009,0 225.81505,222.6678 0 1 1 451.63009,0 z"
   transform="matrix(0.8,0,0,0.8,-82.693286,-58.285845)" /><path
   style="fill:#5b62a3;stroke:#000000;stroke-width:6.40000001;stroke-linecap:round;stroke-linejoin:round;stroke-miterlimit:4;stroke-opacity:1;stroke-dasharray:none;fill-opacity:1"
   d="M 366.375 82.96875 C 221.3619 82.96875 103.78125 200.5488 103.78125 345.5625 C 103.78125 490.575 221.36189 608.125 366.375 608.125 C 410.07803 608.125 451.27894 597.4497 487.53125 578.5625 L 537.5 628.53125 L 601.3125 564.6875 L 559.78125 523.15625 C 602.74288 476.40948 628.96875 414.05403 628.96875 345.5625 C 628.96875 200.5488 511.38809 82.96875 366.375 82.96875 z M 275 218.3125 L 457.78125 218.3125 L 457.78125 472.8125 L 275 472.8125 L 275 218.3125 z "
   transform="scale(0.8,0.8)"
   id="path65" />
</svg>
user4096
Return to QCAD 2.1/2.2 Installation and Upgrades
Who is online
Users browsing this forum: No registered users and 1 guest
