Tip - How to hide the Meta Grid
Clive
Moderator
Post by Clive » Fri Mar 22, 2013 12:49 pm
Here's a little tip for hiding the Meta Grid if you so wish, you cannot remove it but you can hide it!
Go to Main menu - Edit > Application Preferences > Graphics View > Colors > Meta Grid, and in the drop down menu choose ' others' and then in the Select Color dialog window change the value in the Alpha channel to '0'.
This will effectively hide the Meta Grid.
Hide Meta Grid.png (18.47 KiB) Viewed 7901 times
