Sometimes it is useful to select entities by type rather than by location or layer - the following is based on Andrews 'workaround' and a feature request has been added for this option to be added to the 'Selection Tools' tool set:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=630
Workaround Tip - Select entities by type
- select entities by type, 'workaround' 1.png (100.14 KiB) Viewed 11963 times
- select entities by type, 'workaround' 2.png (106.07 KiB) Viewed 11963 times
- select entities by type, 'workaround' 3.png (109.82 KiB) Viewed 11963 times
- select entities by type, 'workaround' 4.png (90.5 KiB) Viewed 11963 times
Re: Workaround Tip - Select entities by type
Hello Clive,
Smart idea, I tried it, quite useful indeed.
