Polyline offset bug
duccoder
Polyline offset bug
Post by duccoder » Tue Sep 27, 2016 3:23 am
Hi, I have a problem with offset polyline (I use QCAD Pro 3.15.5 on linux)
First, I create polyline (white), then I offset (Modify/Offset) with distance = 0.5 & I receive problem as image
Screenshot from 2016-09-27 09-21-52.png (2.41 KiB) Viewed 3653 times
I have been attach dxf file, can you check the problem
offset.dxf
(188.68 KiB) Downloaded 336 times
Re: Polyline offset bug
Post by andrew » Tue Sep 27, 2016 9:54 am
Thanks for your report. Unfortunately, there is no definitive solution to the offset problem (due to the numerical instability of the algorithms involved). The situation can likely be improved by making the algorithm tolerances configurable for a future release.
duccoder
Post by duccoder » Tue Sep 27, 2016 10:18 am
I see, hope it solved on future
